Squeaky chain
4 replies to this topic
  • Red4x4neck
Posted May 09, 2005 - 05:21 PM
Yes I have lubed the chain :) (multiple times
I just recently replaced the rear wheel bearings and seals
I still get squeky noise when I am riding partial throttle and it seems more pronounced when decelerating. I have a 48 tooth rear and I cant remember the front count.
I have looked at the chain guides and there are definite grooves where the chain rides and I am wonder if this may be what is causing the rolling squeak?
Suggestions?
Rob
  • big t
Posted May 09, 2005 - 07:40 PM
I think I have the same noise you're talking about. It sounds like its coming from the counter shaft sprocket on mine. I don't see anything wrong on mine so I'm not worried about it.
  • BWB63
Posted May 09, 2005 - 08:19 PM
Have you guy's greased the swing-arm & linkage bearings? Honda ships theses bikes with nothing more then a film of grease at best in all the bearings, streering stem also. Has been a major problem for lot's of BRP
  • frankstr
Posted May 09, 2005 - 08:43 PM
Is the axle adjustment sqaured from the swing arm bolt, I know on my bike the marks for the rear axle adjustments are not exactly correct.. :D
I measure from the swing arm bolt center to axle center, that way your chain is alighned correctly with the front sprocket to the back... :)
  • big t
Posted May 09, 2005 - 10:14 PM
I have re-greased everything on mine. I know the chain alignment is close but I will double check it. I can only hear mine when I let off and its not that bad.
  • Hot  35 replies
  • 22 replies
  • 9 replies
Washington
  • Hot  32 replies
  • 4 replies
