Some dumb questions
7 replies to this topic
  • byggd
Posted May 09, 2005 - 10:28 AM
1) The WR426 and 450 have the dipstick up in the frame in front of the gastank. How does the frame keep the same level as the engine to give an accurate reading and why did they pump the oil there in the first place?
2) The guy I bought my WR426 from put a temp gage where the dipstick goes. What temp should it rum at and not overheat?
3) Does anyone know if it's OK to run a synthetic oil in a 02 WR426?
Thanks for the help oh guros of thumper land :)
  • tweek
Posted May 09, 2005 - 11:59 AM
Well, Yamalube is a semi synthetic mix. Do not use oil with additives for high efficiency like zinc. It will let your wet clutch slip.
  • Gadsen
Posted May 09, 2005 - 12:28 PM
Technically, the only time the engine is full of oil is when the engine has been setting for a while not running. As soon as its started, its all pumped out. A dry sump system is degigned to keep oil out of the crankcase area, and gearbox in the case of a motorcycle. The oil splashing onto the components rob crank speed and horsepower. More so at higher rpms. So oil is plubed to all the vital areas of the engine via an engine oil pump, then a scavenging pump removes it as it settles in the bottom and pumps it out of the way. That is why you check it after it has ran for a minute or so.
) 2) The guy I bought my WR426 from put a temp gage where the dipstick goes. What temp should it rum at and not overheat?
No idea on oil temps. Just get an idea where it runs during normal riding and in what conditions, then when it varies too much from what your used to, shut it down and have a look.
  • byggd
Posted May 09, 2005 - 12:55 PM
thanks Toyota. I always wondered what dry sump meant. Learn something new every day....guess i can go home now :)
  • shadow171
Posted June 07, 2005 - 09:03 AM
yep yep
  • wr429j
Posted June 07, 2005 - 05:09 PM
When I remove the dipstick to check the level oil runs out (after running the engine). What is the right way to do this?, the manual is no help.
Thanks!
  • Gadsen
Posted June 07, 2005 - 05:29 PM
Thanks!
After you run the engine for several minutes, shut it down, then check the oil level. If it runs out, its too full. Drain some off.
  • pjriss
Posted June 08, 2005 - 07:23 PM
WR's have known heat issues, that's why people put things like temp gauges in oil dipstick holes. Do a search of this forum for keyword "overheating" and see for yourself. I use synthetic oil in all my bikes, even the ones that don't run hot.
