hrc cam
3 replies to this topic
  • mattydog
Posted May 07, 2005 - 09:45 PM
its time to put my old xr 600 back in service . it has a new je piston [10.5] i think big fin ported head and a stock cam with the auto decomp removed[thanks alot xrs only] .i have what i was told is hrc cam w/decomp i am thinking that it will help to slightly lower my compression and make it start better and may help the power to . so the question is is this a tru drop in cam with this piston or will my valves hit or will i have to shorten the guides i do not want to pull the head if i do not have to any coments ?? this cam says nh4 on it is this an hrc cam?? thanks :)
  • XRMANU
Posted May 08, 2005 - 05:11 AM
NH4 is the HRC code,yes :)
  • mattydog
Posted May 08, 2005 - 09:52 AM
thanks xrmanu do you know if it just drops in ?
  • frankstr
Posted May 08, 2005 - 11:21 AM
Always, When installing a bigger cam piston to valve clearance and valve retainer to valve guide clearance should always be checked.... :)
Unless you know of someone with the same set up and it all worked....
But it should always be checked due to manufacture errors....IMO.... :D
And make sure the springs will work , No coil bind, proper spring pressures..
  • Hot  186 replies
  • Hot  35 replies
  • 3 replies
Washington
  • Hot  32 replies
Honda XR650L 2017
  • 0 reviews
