changing oil......?
4 replies to this topic
  • offrodeo
Posted May 07, 2005 - 09:40 AM
i havent bought a manual yet for my bike and i really dont want to ride on 10 hour oil. Can one of you quickly tell me the right way to change my oil on my 03 450f? Where to you guys get your oil filter?
kevan
  • SureBlue
Posted May 07, 2005 - 10:31 AM
Kevan, you can download a manual from ThumperFAQ:
http://www.thumperfa.../oemmanuals.htm
and you may also want to learn to use the search feature up in the header of this page
HOME FORUMS STORE CHAT SEARCH HELP
Posted May 07, 2005 - 04:23 PM
The procedure on ThumperFAQ is for a YZ250F, but the procedure for the '03 model is exactly the same as called for with a YZ450F, so in spite of the size difference, the info applies.
  • ONLY4STROKES
Posted May 07, 2005 - 04:29 PM
1. get your filters and oil from your friendly, local yamaha dealer.
2. take the dipstick out (this helps the oil drain out faster).
3. undo the drain bolt in the frame, draining the oil.
4. undo the drain bolt in the crankcase (under the shifter), draining the rest of the engine oil.
4. unbolt the oil filter cover, and take out the oil filter.
5. clean the interior of where the oil filter sits.
6. put the clean oil filter back in its proper place and bolt the cover back on.
7. fill the engine with the proper amount of oil.
www.thumperfaq.com
  • offrodeo
Posted May 09, 2005 - 06:48 AM
i would of used the search button but i was in such a big hurry to go riding. I was literally pushed out the door. Then i had to come back and read the reply's. Thanks for the info guys.
kevan
  • 10 replies
  • Hot  47 replies
  • Hot  50 replies
  • Hot  38 replies
  • Hot  36 replies
