stock sag???
4 replies to this topic
  • gunship426
Posted May 06, 2005 - 02:07 PM
hi every one. i have a 2002 yz426. can anyone tell me what the stock sag is for it?
  • Fastest1
Posted May 06, 2005 - 02:37 PM
Most long travel bikes seem to be set for about 100mm sag in the rear a little more in the front. That is with gear and fuel.
Posted May 06, 2005 - 03:28 PM
Measure from any reference point on the rear fender to the axle with the bike on the stand. Then, with at least your boots and helmet, stand on the pegs and have someone measure from the axle to the same point on the fender. The difference is your "race sag".
With the bike on the floor, under only its own weight, measure the same points again. The difference between this and your first measurement is your "static sag".
Race sag should be about 100mm (4"). Between 107mm and 93mm is OK (4 1/4" - 3 3/4").
Once you set the rag sag, check your static. It should be 25mm (1") with the race sag at 100mm. If it's more than that, your spring is too stiff. If it's less than 25mm, it's too soft.
First: http://www.tootechra...ension_tips.htm
Then: http://www.tootechra...pension Tip.htm
  • gunship426
Posted May 06, 2005 - 06:10 PM
thanks so much guys Illtry it tomarow...
  • YZ250F_Rider
Posted May 06, 2005 - 06:55 PM
If it's around 1" it's ok too, it will vary as you vary the race sag. 2" or a 1/4" would be bad.
  • 9 replies
  • On January 15, 2017
