oil in stator side?
10 replies to this topic
  • miguelitro
Posted May 06, 2005 - 10:06 AM
Am i correct in assuming that there should be a little oil in the stator/mag side or is it supposed to be dry???
thanks
Mike
  • AzMtnThumper
Posted May 06, 2005 - 10:43 AM
XR650R = dry
XR600R= wet
  • miguelitro
Posted May 06, 2005 - 10:46 AM
ooh boy would that mean a blown seal on the crank? what would that entail??
oh s$%t...
  • miguelitro
Posted May 06, 2005 - 11:08 AM
i've also heard that about table spoon is normal but cant remember where i read/heard it???
  • mikekennedy
Posted May 06, 2005 - 10:55 PM
I put my shifter through the the case of my 650L, to find a pile of oil expelling out as well. This forum taught me that MANY XRs are wet stator. Not sure about 650R, but the engines are quite similar other than a tad more compression on the R. Both dry sump lubrication, but am not sure if the ignition is the same. Hmm, how much help am I?
  • Winkel
Posted May 07, 2005 - 07:23 PM
On the 650R it's dry. When I rewound my stator there was a little in the bottom, maybe a teaspoon. I wiped it out, (about a year ago), and when I removed the cover last week to get TDC during a valve adjustment it was still pretty much dry. A very small amount is probably no problem.
Just my two cents.
Winkel
  • XR4DEZ
Posted May 07, 2005 - 08:58 PM
Winkel, why not move the kick starter to find TDC rather than taking off the side cover?The allen screw in the side case has a notch that lines up with the spot on the flywheel. :)
  • The Haymaker
Posted May 08, 2005 - 03:59 AM
Don't worry about it. That tablespoon will keep things from rusting. :-)
Seriously though, the stator cavity sucks oil through the seal when things cool off. Once you've had it apart a few times you'll never get a tight enough factory seal to get the problem anymore.
SRC sells an overpriced breather tube meant to cure this. Don't bother........
Winkel, I'd pull the cover too. It's a PITA to time this thing through a hole.........
E
  • Winkel
Posted May 08, 2005 - 08:26 PM
I started to pull the plug, but the damned thing was so tight I thought I'd strip out the allen head. It only took a minute to remove the cover, but when I was done I got the plug loose. I'll do that next time, but it was my first valve adjustment, so I wanted to be sure about the position.
Winkel :)
  • miguelitro
Posted May 09, 2005 - 08:09 AM
thanks for the info guys and haymaker love your site!!!
rode the pig in the piute mnts above jawbone-seriously tight single track, technical, heck never got it out of 2nd gear, but was amazed how well this thing did, probly better than me
lost about a 1/4 cup of coolant
I love my piggie!!!
  • JackAttack
Posted May 09, 2005 - 08:15 AM
I find it easier to put the bike in 5th gear and spin the back tire with your foot, while you peer into the check hole for the flywheel mark. :D
<Edit> Make sure you spin the wheel the right way.
  • 17 replies
  • 9 replies
  • Hot  35 replies
  • 3 replies
Honda XR650L 2017
  • 0 reviews
