Power now?
6 replies to this topic
  • 96warrior
Posted May 05, 2005 - 07:36 PM
I did a search, and nothing really came up.
But is the "Power now" worth the money? Or is it just a fad, like buying a tornado from my truck(no I didn't buy one)?
Was wondering if it would clear up the lower mid-range stumble I'm having, and make the bike more responsive. I like to lug and chug when I ride by myself.
  • dominator426
Posted May 05, 2005 - 08:58 PM
It does improve low end response, grunt and starting ease. It's well worth it. Your stumble may be caused by a slightly lean condition. The Power Now Valve increases air velocity at low throttle openings which would intensify a lean condition. A lower clip position or richer needle should cure it.
  • tp3dxf
Posted May 05, 2005 - 09:14 PM
Mine seemed to aid a little in starting and a slight improvement in throttle response. Nothing earth shattering.
  • rockieman
Posted May 06, 2005 - 05:16 AM
A few years back there was a post on making your own.....complete with a template for cutting out the piece of aluminum. Hacksaw both sides of the intake, a little JB Weld and you're done.
I did mine and it cost me about an hour and pennies worth of material.
Maybe someone else still has the link
  • simica
Posted May 06, 2005 - 06:13 AM
I believe it improved my throttle response and low to mid range. Install was clean and easy. Its worth it.
  • Chris_from_Oz
Posted May 06, 2005 - 06:37 AM
There should be a PDF file somewhere on TT, that has the instructions for the homegrown PowerNow. I made one (a few actually), and I can vouch that they increase your bike's 'chugability'. There was a particular deep sandy corner, that my bike would usually bog down in 2nd gear on. With the homemade PowerNow, I could smoke that same corner, no bogging, just roost..... :) :D :) They DO work.....
  • eightballeddy
Posted May 06, 2005 - 12:35 PM
I think the home made version was called the James now. Try a search and see what you come up with. :)
