key ignition
6 replies to this topic
  • mmi100sguy
Posted May 03, 2005 - 10:20 PM
my 04 has a button ignition switch. i'm gonna be using it as a commuter and would like to have some extra security(obvious security) of having a key style ignition. where can i pick one up? can i use one off an 03? anyone doing this?
  • ddialogue
Posted May 04, 2005 - 03:28 PM
I did and it works GREAT! I used the key switch off a TT-R125LE. $55 bucks for the setup at the local Yami shop. The reason I went with the OEM switch over a cheapy aftermarket was that I could wire this one so easily. The wiring for the TTR is identical to the WR and all I had to do was extract the pins from the TTR connector and reinsert them (in the same locations) into the WR connector.
Here's a few photos of what mine looks like:
WR450 Key Switch
  • KiltLifter
Posted May 04, 2005 - 03:40 PM
If you relocated the original button to somewhere hidden, you could put in a fake switch that would fool the theif, that's my plan. The only difficulty will be relocating the red indicator light with the button so you would be sure to see it. I left mine on overnight once and it started just fine, so I don't think "on" draws any current except the LED (or I was lucky). :)
  • mmi100sguy
Posted May 04, 2005 - 06:25 PM
cool, thanks a bunch
  • simon@vic
Posted May 04, 2005 - 06:50 PM
drz400e/klx400r one works well too.
the best protection you will find is with a big cable lock !!
  • kincade
Posted May 04, 2005 - 09:44 PM
If any of you guys are looking for a switch, I think I may have accidentally bought 2 of the exact switches from the TTR... PM me offline.
  • 4mud
Posted May 05, 2005 - 04:00 AM
I put a keyed switch on my 04. The best one I could find was for a Honda CRF230, it was less than half the price of a Yamaha one. It also has 2 sets of contacts so it can be wired in to the kill switch circuit as well as replace the power on switch. I made a bracket to mount it in the stock location and added a LED for indication. Looks factory and was easy to do.
