YZ triple clamp offset on a WR
4 replies to this topic
  • Anravqsuh
Posted May 03, 2005 - 07:21 PM
Has anybody out there ever done this? My understanding is that the angles/ offset are different and the YZ should have an offset that handles better. Right? Wrong?
  • simica
Posted May 03, 2005 - 09:48 PM
I have the GYT-R YZ top triple clamp and the stock WR bottom clamp. I don't know if it made a difference cuz I made alot of changes at the same time. I guess you would need a YZ bottom clamp also to know for sure. All I know is I love the way this bike turns and overall, handles better than anything I've ridden.
  • Hamish
Posted May 04, 2005 - 12:15 AM
My situation is similar to Simicas. I have a SPP top clamp (which is marked as YZ426) on my WR. If the geomoetry wasnt exactly the same the forks wouldnt line up with the tripple clamps properly.
  • RCannon
Posted May 04, 2005 - 03:57 AM
The wr and yz clamps will have the same offset. You may notice a handling difference because the bars move foreward on most aftermarket clamps, but the offset is the same.
I did try a set of 22mm offset clamps on a WR 400. I felt like the bike turned much better. I never did take thsi bike to high speed so I would hate to comment on high speed handling.
  • RADRick
Posted May 04, 2005 - 08:58 AM
I had a stock YZ top clamp on my WR (to mount a YZ number plate) and recently changed to an aftermarket one. There is no difference in offset or handling. Tag Metals does make a triple clamp set with 22mm offset, but you can't get an offset by simply changing the top clamp. It has to be built into the complete clamp set.
