chain adj. nut size?
6 replies to this topic
  • tnl
Posted May 03, 2005 - 07:44 AM
What size is the lock nut on the chain adjuster on the 05 450?
  • SureBlue
Posted May 03, 2005 - 09:16 AM
12 mm
  • tnl
Posted May 03, 2005 - 07:16 PM
Thanks. I really stripped mine..
  • Chad76
Posted May 05, 2005 - 06:13 PM
TNL......yeah I found the same on my 04 model. It almost seems like a in between size. I rounded mine on my first change. They are a b!tch to get at as well. Not much room for a spanner. Ive just made sure I dont do them up so tight so it dosent happen again.
  • tnl
Posted May 05, 2005 - 07:07 PM
I know what you mean. Did the same thing with mine at the first adjustment. Later I tried a 10mm,11,12,13 and all non metrick sizes after the first adjustmentand none will fit now? Need to be right on the money every turn every time I guess?
Posted May 05, 2005 - 07:44 PM
Don't ask me...I'm told I don't understand how a chain is tensioned. :)
But if you did, I would suggest trying to find a 12mm Flare Nut Wrench. These are like a six-point box end with a slot cut in the end of them so they can be slid over a fuel line, brake line, etc., and still drive the flare nut on more than two opposite sides. You can cheap out and cut a slot through a 12mm box end, but the opened ring of a standard box will not likely be strong enough to avoid springing open and slipping. The jaws of a flare nut wrench are beefy and built for the job. In fact, if you use a standard Craftsman, you may have to grind the ends of the jaws just a little to get it to fit in next to the swing arm. I keep a Snap-on FNW in my tool box just for the chain adjusters. :D
  • SureBlue
Posted May 05, 2005 - 08:31 PM
Yeah gray, I'm sure you don't... :) :D
  • Hot  113 replies
  • 9 replies
  • 0 replies
  • On January 15, 2017
