Oil Changes
3 replies to this topic
  • Guest_Guest_*
Posted November 10, 2000 - 05:51 PM
I was wondering how often the oil screen at the bottom of the frame needs to be cleaned out. What size socket is required?
1999 WR
  • John_in_Long_Beach
Posted November 10, 2000 - 07:29 PM
I recently checked this screen because I had heard some reports of them being packed with crap after only a short period of time.
Somewhat panicked, I checked mine for the first time with about 1000mi on the od and nothing. Perfectly clean.
So based upon my experience I won't be too concerned. Of course, maybe somebody else has had a different experience.
  • Dougie
Posted November 10, 2000 - 07:38 PM
It is more important that you check it after the initial break-in period or first couple of rides.
I never did. I checked it around 1500 miles and only a very tiny amount of junk was there. Haven't checked it since.
Not sure of the wrench size but I do know one thing...you will have to pound on that thing to get it loose the first time. One of the reasons I never checked it early was because I couln't get it loose. I thought it was even welded shut. It actually looked like part of the frame. I finally just took a mallet to it and it finally came loose.
  • Dave_VanBrocklin
Posted November 11, 2000 - 02:59 PM
I cleaned mine the first few oil changes, and I found ALOT of junk in mine, metal from machining, even blue paint. The nut is 24mm,I believe. now that my bike has a few miles on it, I check the screen every 3rd oil change.
