Missing Main Jet
7 replies to this topic
  • Seabass
Posted May 01, 2005 - 03:41 PM
I finally broke down and bought the JD jetting kit for my '05 WR 450. After installing the Blue needle in the 4th position I figured I'd better check my main jet and make sure it was right for the new needle. I was shocked to find out that the main jet was missing :naughty: . Since my last jetting change I've done two play rides (one was over 100 miles), raced two desert races (one a National Hare & Hound) and I never would have guessed that my bike would run as well as it did without the mj!!!! I musta left it out and just put the float bowl cover back on. :naughty: I was having a slight pop/ bobble when I was running at 1/3 throttle and figured I'd give the JD kit a try to solve the problem. The funny thing is I've had the two best races of my life riding a bike witout a main jet!!!!!
  • tp3dxf
Posted May 01, 2005 - 03:55 PM
That is amazing. Either these motors are bitchen or you never hit your main jet? How did it run wide open?
So that is how I was able to pass you. Kidding.
  • Seabass
Posted May 01, 2005 - 04:01 PM
It ran really good!!!! At the Vikings H&H I had it wfo thru some of the sand washes and it was as fast as I've ever been in a District race. Who knew :naughty:
  • Indy_WR450
Posted May 02, 2005 - 04:35 AM
Thats because you have a fixed 200MAJ to support the main jet feed. :naughty:
  • Seabass
Posted May 02, 2005 - 02:16 PM
Aha!!! Now what's a MAJ? Main Air Jet?
  • thumper_dad
Posted May 03, 2005 - 05:35 AM
Pretty sweet aye
  • Dan_Lorenze
Posted May 03, 2005 - 07:22 AM
Seabass, Didn't you initially have problems with a Big gun pipe? This could've been your problem with the bogging over whoops... (if my memory serves me correct).... :naughty:
  • Seabass
Posted May 03, 2005 - 02:25 PM
Seabass, Didn't you initially have problems with a Big gun pipe? This could've been your problem with the bogging over whoops... (if my memory serves me correct).... :)
I'm sure that the main jet was in when I first put on my Big Gun pipe. I ended up putting the Big Gun back on and have sincetgotten the jetting dialed in. I can't remember the last time I checked my main jets, but I had a dealer go thru the carb after sucking in a bunch of sand a little while back. I ended up finding some missing hose clamps etc that they eventually replaced, so maybe they forgot to put the main jet back in?? More than likely it was me in a rush to put my bike back together :D The Big Gun with the quiet insert ain't half bad, but in race mode is waaaaay too loud
