grinding grunt when letting the clutch out....
21 replies to this topic
Posted May 12, 2005 - 08:09 PM
#21
I drained both, I also pulled the filter. The filter looks like the K & N type filter (maroon color) and it wasnt paper so i cleaned it and put it back. On the oil filter cover, what type of gasket or seal is there to seal it on? I didnt seem to find one. So today ill start it up, let it warm up, let it sit for 5 min. check the dipstick add/subtract if needed.
kevan
There are 3 small O-rings and one the size of the cover. No gasket.
  • Goosedog
Posted May 13, 2005 - 04:39 AM
#22
Mine used to groan too, started using Yamalube 4R and problem solved. :) Be sure to change you oil every third or forth ride too, as it's a small amount (1 1/2 qrts) and contaminates quickly.
