Flaming Exhaust
4 replies to this topic
  • gmiles
Posted April 24, 2005 - 07:34 AM
Rode today and my 426 was poping on deacceleration. Well it got louder and louder. I came off the track and grabbed a handfull of throttle and when I let go with each pop flames came out of the exhaust.
A bit of background....
I got the 426 which had a stock header and an Arrow pipe. I managed to get hold of a ProCircuit setup, header and a couple of pipes from H4B. I ran the PC header and the shorter of the pipes for the last year. The PC setup gave more bottom end and better throttle response. A couple of weeks ago I was racing at Canada Heights and decided that I would run the longer pipe. Well I had it sound checked and it was registered at 102db. This pipe is quiter than the shorter pipe. It also gives less power at the bottom end.
Anyway I thought I would do my bit for the noise problems, so I put the stock header and Arrow pipe back on. This is alot quieter but unfortunately not as powerfull.
I used to run Optimax in the bike but recently I have run on normal pump gas. My son said his bikes runs better on Optimax so this weekend I switched back.
So the difference between this weekend and the last time I rode was the stock header, Arrow pipe and running Optimax.
What could cause these flames. It did look good though. Some kid said he wished his bike did that. I said I wished it didn't.
  • gmiles
Posted April 24, 2005 - 08:05 AM
Sorry Gents, I pasted this from another forum in the uk. Optimax is premium pump gas from shell. Its rated at 97 Octane, standard pump gas is 95.
Posted April 24, 2005 - 10:01 AM
Decel popping is caused by either an air leak in the exhaust, probably the mid pipe joint, or lean idle mixture. Do a quick check of the exhaust system. If it's OK, back the fuel screw out a quarter to a half turn. No big problem in any case.
  • MichiganMXer
Posted April 25, 2005 - 05:50 AM
Bad gas
  • gmiles
Posted April 25, 2005 - 08:06 AM
Found the problem. One of the bolts holding the header to the cylinder had fallen out.
Thanks for the help.....
  • Hot  30 replies
  • 0 replies
  • Hot  28 replies
