Kritters' beefier footpeg arm install
5 replies to this topic
  • needsprayer
Posted April 23, 2005 - 05:02 PM
Installing Kritters' modified footpeg arm.
New beefier footpeg arm
After drilling I filed down the frame weld
Filing weld to make space for a washer
Tapping in the stock shim
Finished job frame view
NP says
  • KeithBoyd
Posted April 24, 2005 - 12:13 AM
Sure looks the job!!!....he needs a Eurpoean distributor!!!!....
  • frankstr
Posted April 24, 2005 - 05:12 AM
Nice job.... :naughty:
LMAO on the last pic............... :naughty:
  • Kritter
Posted April 24, 2005 - 04:53 PM
the boss that you filed down appears hammered maybe its just the picture. Did the peg fit snug before bolting it? It should take a little effort to get the washer behind it on the back side...shoudnt need to be grinded though. I will double check my fixture.
Glad you like it. That new front bolt has some special coating too that shouldnt rust like black oxide does.
  • needsprayer
Posted April 24, 2005 - 05:45 PM
Kritter,
The boss was not hammered. The boss was either uneven or I was drilling slightly downward or both. There was some space between the bracket and boss up top but none at the bottom to allow for the washer to be inserted. A little filing is all it took. The peg arm bracket fit so snugly that I had to tap the stock shim in with a small hammer. All in all a very easy job.
thanks
NP
  • Kritter
Posted April 25, 2005 - 06:29 AM
Gotcha...just wanted to make sure you werent doing any extra work.
