xr 650l started ticking then died
7 replies to this topic
  • award900
Posted April 21, 2005 - 05:22 PM
Ihave an 01 xr650l with 7500 miles on it. Was riding for a few hours, Noticed the bike started ticking, then it lost power and quit. It would restart, run for a bit then quit. The bike had oil. I ate lunch and let it cool down(it didn't seem overly hot) After lunch ,no ticking, ran fine till it got hot, same deal.
Spark plug looked fine, Checked the valve clearance, fine. Changed the oil and filter, dirty but fine.
Now it starts fine and runs ok( I've only ridden in the neighborhood) but as it gets warm I'm hearing a tick and I don't have much faith in our local dealership. Any help, much thanks... Alex :naughty:
  • hoptup
Posted April 21, 2005 - 05:58 PM
Are the valves adjusted properly? Is the intake manifold still sealed properly -- (leaning out?)
  • targetdrone
Posted April 21, 2005 - 06:26 PM
Often an exhaust leak will cause a ticking sound. Exhaust leaks can lead to burnt valves.
  • KIWIWAY
Posted April 21, 2005 - 07:00 PM
Had the same problem last weekend riding out in Borrego Springs. It was 100+ the bike started ticking when real hot.Turned out to be the smog block off kit, in the front of the head. Bolts come a little loose. Well I hope that was the problem :naughty: John
  • Motosprtman
Posted April 22, 2005 - 10:35 AM
or worst case scenario the oil pump is going.... they will often make a ticking sound cold and then go away when warmed up
  • award900
Posted April 24, 2005 - 08:14 PM
Thanks Bros, I checked everything except the oil pump. The weird thing is it does not tick until it gets warm. I'm looking into the oil pump. seeyabye, Alex
  • LotsOfBikes
Posted April 25, 2005 - 07:35 PM
You may want to check your automatic compression release. It may be sticking when hot, and keeping your exhaust valves open. I've heard of it, but have never experienced it first-hand.
  • award900
Posted April 25, 2005 - 09:11 PM
Thanks Sean! I'm workin the pit's out in California for the AMA superbikes this weekend but I'm lookin into that as soon as I get back!! One other thing someone mentioned is the oil screen. Does anybody Know where that beeeotch is??! Thanks again brothers.
Alex.
P.S. Sick van jump. Is that an E onefivezero?
