Chain Tension on a 426
8 replies to this topic
  • beasleys
Posted April 21, 2005 - 01:26 PM
What is the correct way to set the proper chain tension on my 01 426? I set it with two fingers on top of the swingarm but when I do that it makes a poping noise when getting on the power in first or second. I think the noise is the chain slapping the swingarm. When I adjust the slack out enough for the noise to stop then the chain is pretty tight towards the bottom of the suspension stroke. What is the right way?
  • 02YZ426
Posted April 21, 2005 - 01:32 PM
I like to have 3 fingers slack in the chain right behind the guide. How old is your chain+Sprockets? If they are worn, the chain will chatter more. I found a big difference when I went to an o-ring chain, there was alot less chain noise.
Posted April 21, 2005 - 01:37 PM
I believe the spec is 1 5/8" or 1 3/4" with the wheel hanging free. It's important to set it while it's on a stand, because the spec takes into account the slack taken up by the lower roller.
Chain slap at low RPM is pretty normal.
  • beasleys
Posted April 22, 2005 - 05:44 AM
The chain, front sprocket, and rear sprocket all only have approx 10 hours on them. I replaced them all as a set.
  • Matt96xr6
Posted April 22, 2005 - 06:21 AM
2-3 fingers at the last bolt on the chain slide. That is where you measure it. I usually set it about 2.5, just where I cannot get the 3rd finger under there.
  • Daz_426_02
Posted April 22, 2005 - 07:07 AM
I would defiantly agree with the O-Ring Chain being much quieter !!
  • mark794
Posted April 22, 2005 - 09:57 PM
Its gonna slap in the lower gears even when adjusted right. Keep an eye on the guides to make sure its not wearing through. Motoman has a pretty good article on it on his web site @ http://motoman393.thumpertalk.com/
An O Ring Chain worked better for me.
  • Satch0922
Posted April 23, 2005 - 05:38 AM
doesnt the shop manual say 1.7-2.0 inches of play ?
  • Satch0922
Posted April 23, 2005 - 05:43 AM
sorry... 1.6-2.0 inches of play per the manual
  • Hot  50 replies
  • Hot  28 replies
