Coolant Change
6 replies to this topic
  • WaGuy78
Posted April 21, 2005 - 11:35 AM
How often should you flush and change your coolant? I have a new 05 450 with about 250 miles on it... Is it time?
Also, what do you guys add to the water?
  • sharpmarble
Posted April 21, 2005 - 12:29 PM
I'm not sure about the change interval, but I recommend engine ice premix, it's good stuff :naughty:
  • rockieman
Posted April 21, 2005 - 01:18 PM
My manual says every 2 years which is what I adhere to. If you ride in extreme conditions (hot) you may do it more frequently.
  • WGP
Posted April 21, 2005 - 02:02 PM
I going with once a year, every 6 months if racing :naughty:
  • Shuffler
Posted April 21, 2005 - 02:04 PM
on that note, are there any tricks or 'gotchas' when changing coolant? stuff like making sure there are no air bubbles in the system etc. Is it easy enough to do?
I run Engine Ice in the big KTM, and will run that in the YZ & WR when I get around to changing the fluid. It's more expensive, but good stuff.
  • minion
Posted April 21, 2005 - 07:09 PM
You might check out this post from ncmountainman:
http://www.thumperta...ghlight=coolant
He uses something called NPG-R in his bike. He has had numerous boiling over problems on his bike (tight single track / slow riding), and switched to this stuff. Solved his problems.
  • xcracer123
Posted April 24, 2005 - 10:44 PM
Agreed! The NPG-R is the way to go if you have overheating problem. If you are just wanting to know what to add to your 50/50, pick up a gallon of distilled water. No corrosion that way!
