Question on installing piston rings-which is which
3 replies to this topic
  • michaelschorpp
Posted April 20, 2005 - 05:26 PM
I'm rebuilding my 92 XR600R and am trying to put in the new rings. The online shop manual I'm using isn't specific enough on the two compression rings. One is black with a rectangular cross-section, marked 1N 50. The other one has a bronze like appearance, and is bevelled on the inside edge. it is marked N50. Which ring is the top ring, or does it matter?
Mike.
  • frankstr
Posted April 20, 2005 - 06:21 PM
IMO the bronze looking one is the top ring, Its a coating of some type..
The second ring is just cast iron.........
  • justicedone
Posted April 21, 2005 - 11:01 AM
I dont know sorry, but from my car engine building experience I can advise you keep the notches 180 degrees apart on piston. Check your manual.
  • StevePSD
Posted April 21, 2005 - 12:04 PM
Take a look at the grooves on the piston. You should be able to see which ring matches up. Typically the one that is 'triangular' in cross section is known as a Dyke's ring and is the uppermost ring on the piston. The beveled surface faces up.
Hope this helps.
Washington
  • Hot  32 replies
  • Hot  60 replies
Honda XR650L 2017
  • 0 reviews
  • 3 replies
  • 8 replies
