NEED BOLT SIZE. WR/YZ seat bracket
3 replies to this topic
  • lilmule400
Posted April 20, 2005 - 06:39 AM
Anyone know the size of the 4 bolts used to attach the two brackets on the rear of the seat? I just got a WR tank/seat and my current SDG seat has studs instead of bolts.
  • simimi
Posted April 20, 2005 - 07:30 AM
Interesting, the manual does not show those. If no one else posts, I will check my bike tonight. My guess is they are M6 or M8 x .5 but not sure. You can check easy, if they are the same size as the Side plate mount or Rad Scoop mount they are M6, if they are the same as the Seat bolts (the ones throught side panel, seat and into frame) then they are are the M8
Mike
  • adrian
Posted April 20, 2005 - 07:58 AM
They are 6X1.25 standard 6mil bolts that come one the bike....
  • lilmule400
Posted April 20, 2005 - 08:45 AM
Thanks! I just picked up the bolts at lunch. The seat and tank go on tonight!
  • Hot  50 replies
  • Hot  36 replies
  • Hot  38 replies
  • 10 replies
