wiring problem - help
No replies to this topic
  • sm-wr
Posted April 20, 2005 - 04:05 AM
i have an 02 wr426 with the full lighting kit fitted, the problem is that it keeps blowing the indicator/flasher relay. i have checked the voltages at the regulator & that is fine <14v. but i seem to be getting anthing up to 35v ac to the flasher relay(12v @ idle & goes up as revs increase). the voltages at the lights are ok & i dont have a problem with blowing lamps. i cant work it out as they all seem to be feed from th same supply.
HELP!!!!!!!!!!!!!
