When doing auto-cam, should I.......
24 replies to this topic
  • Crabtree426
Posted April 19, 2005 - 05:32 AM
Should I replace any other parts? Are ther any known problem points in the motor? A friend mentioned the cam chain.
  • Vibeguy
Posted April 19, 2005 - 06:47 AM
If you are going to remove your manual decomp system be sure to install the TT decomp plug. The $3 part that Yamaha sells won't stay in.
Posted April 19, 2005 - 07:28 AM
Cam chain is a good idea. Be sure to check valve clearances after the new cam is in.
  • Crabtree426
Posted April 19, 2005 - 08:32 AM
That's what I've been hearing so I ordered the TT plug yesterday.
  • Crabtree426
Posted April 19, 2005 - 08:33 AM
Do you know where the best place for shims is if I need them. Just thinking ahead. Thanks
  • Crabtree426
Posted April 19, 2005 - 08:35 AM
Someone told me that the TT plug use to be like 5 or 6 bucks. It's 22 now, ooooooooooooooouch.
  • cowboyona426
Posted April 19, 2005 - 09:49 AM
It's more $ now because it's anodized and because it comes with the seal.
  • Btwick
Posted April 19, 2005 - 10:32 AM
I justified it cause Yamaha wanted $170 to do the cam swap, but with the help from the kind folks on TT, I did it myself. The Yamaha plug is $3 but *can* fall out, and I've heard of some just cutting off the decomp lever at the head and grinding off the tab that opens up the exhaust value. Free and won't come out..
  • Crabtree426
Posted April 19, 2005 - 12:12 PM
That would make sense then. Cool, it's worth the $ not to worry about it blowing out.
  • Sylvain
Posted April 19, 2005 - 01:24 PM
And to have it shipped to my location there was extra shipping fees. That's why I decided to make one. I took the measurement of the decomp shaft and machined the plug. It replaces the shaft without the valve actuator, and use the same seal. :naughty:
Posted April 19, 2005 - 02:19 PM
For shims, you can use either the Yamaha or CRF450 shims from the appropriate dealer.
The Yamaha plug has been used with a piece of aluminum angle bolted over it to retain it (tacky looking), or safety wired over (tackier still, and shaky, to boot). I'm sure that if you looked hard enough you could find a steel cup plug at an auto parts house that fit either the seal pocket or the shaft bore properly and use that. But the TT plug requires no research and looks cool. :naughty:
  • Satch0922
Posted April 19, 2005 - 05:18 PM
just take the decomp mechanism out and saw the "lever" end off with a hacksaw and reistall it. Basically you have then made your own plug.
  • cowboyona426
Posted April 19, 2005 - 09:38 PM
This coming from the guy who looks for any excuse possible to add bling to his own bike :naughty:
Just get the TT decomp plug, it looks good and the $ go back into the site.
  • Satch0922
Posted April 20, 2005 - 04:47 AM
Jealously is the sincerest form of flattery :naughty::naughty::D:D:D
Posted April 20, 2005 - 10:52 AM
If you hack up the decomp shaft to make a bore plug (which is OK to do), you MUST remove the inboard end of the shaft that acts as a cam to lift the valve. If left in place, and assembled with no return spring, the manual decomp shaft could rotate itself with the engine running and contact the cam follower with possible disastrous results. Cut it off just past the groove for the retention bolt, where it steps down to a smaller diameter and turns half-round. Be sure none of it overhangs the cam follower.
  • Satch0922
Posted April 20, 2005 - 01:06 PM
Good point GrayRacer! Some people actually add to the thread... :naughty:
  • Crabtree426
Posted April 21, 2005 - 09:17 AM
I guess that's why he's a Titanium member. Thanks GrayRacer.
Posted April 21, 2005 - 09:23 AM
No, I'm Ti only by virtue of having opened my mouth 2000 or more times. :naughty:
I was right once, it means nothing. :naughty:
Don't be diissin' Satch, now. :D (jk)
  • RJB
Posted April 21, 2005 - 12:55 PM
I was right once, it means nothing. :D
...and Satch is only 11 post shy of being Ti too :naughty:
  • Satch0922
Posted April 21, 2005 - 01:18 PM
just 9 short now ( sorry for the shameless post)
  • Hot  28 replies
  • 3 replies
  • Hot  113 replies
