Oil Type help
7 replies to this topic
  • JAJA208
Posted April 18, 2005 - 01:02 PM
Hi All,
I just purchased a 1999 Yamaha YZ400F used. I also purchased the service manual. The service manual says to use a 10w-30 or 10w-40 type oil. Is this ok to use or is there something better I should use. I changed the oil when I bought it and havent ridden it yet. I put 10w-40 in it. I just wanted to check with you all before I go riding and do any damage. I appreciate any help you could give me. This is my first 4 stroke, My last bike was a 1983 YZ490 2 stroke and there is alot to get used to. Thanks everyone!.
  • Ga426owner
Posted April 18, 2005 - 01:15 PM
ok did you just go put any old auto oil in it or 4stroke oil or what? Some will deteriorate the clutch -
You can do a search for more info than you ever dreamed of -
I would suggest Yamalube 4 or yamalube 4R if you are unsure -
I run 15-50 - Mobile1 RedCap - but please do not follow my lead - :naughty:
  • yamahauler44
Posted April 18, 2005 - 01:20 PM
i use valvoline 10-40 motorcycle oil designed for wet clutches, the best oil ive ever used in my 99 yz400f
  • ovrrdrive
Posted April 18, 2005 - 05:05 PM
While it won't damage the engine, if the oil you used was marked "energy conserving" it could make your clutch slip.
But most of the 10w-40's I have seen don't have that designation.
What did you use?
  • JAJA208
Posted April 19, 2005 - 02:14 PM
I had Just regular 10w-40 motor oil in it but due to yours and everyones reply I went out and bought Bel-Ray 10w-40 4 stroke motorcycle oil. Do you think this is a good choice?. Thanks for your input.
John
Posted April 19, 2005 - 02:24 PM
Yes, it's a good choice. I'm not familiar with it, but if it meets Yamaha's grading specs (API SG, SH, or higher), and is either graded JASO MA, or labeled as specific to motorcycle engines with wet clutches, and is NOT marked as Energy Conserving, then it will at least do the job. If it's a good full synthetic, that's even better.
  • JAJA208
Posted April 19, 2005 - 02:41 PM
Grayracer,
The exact name and type oil is Bel-Ray EXL motorcycle motor oil, SAE 10w-40 (API SG, JASO MA). The write up on the back says "A premium multi-grade petroleum motor oil for 4-stroke motorcycle engines. Equally suitable for air-cooled and liquid-cooled 4-stroke engines". Is this a good oil?.
John
  • DoctorRzed
Posted April 19, 2005 - 04:09 PM
Yes that is a good oil to run in your bike :naughty:
  • Hot  47 replies
  • 10 replies
  • 5 replies
  • 0 replies
