XR600 oil overfill?
6 replies to this topic
  • robxr600
Posted April 17, 2005 - 10:50 AM
Just changed oil in my XR600. Emptied crankcase and reservoir. Put in 1 quart and idled for a minute then filled it up. Total of nearly 3 quarts! Drove it around for 2-3 minutes and checked level.... near the top. Opened side plug and had some oil slowly come out maybe 3-4 ounces. Bike has few miles (under 10K). Is this normal? Engine sounded ok. No smoke.
  • Sportster
Posted April 17, 2005 - 10:59 AM
They hold 2 quarts with just an oil change, 2.06 with filter.
  • don87xr600
Posted April 17, 2005 - 12:22 PM
2.6 qts. if you remove a side cover
  • beer_studd_76
Posted April 17, 2005 - 04:15 PM
that's good to know
  • bikerider420
Posted April 17, 2005 - 09:31 PM
(First bike so im kind of a noob) I recently bought a used 95 honda xr650l and its got 1400 miles on it($600) + alot of parts for it, they used it offroad, no blinkers on it, anyways I dont know verymuch about bikes but im going 2 learn, I put about 85 miles on it and Im pretty sure there was 2 much oil in it because the person abused it pretty much. It was fast as hell for awhile then it started too bogg out on me as I gave it more gas / less response then it would stall....
while coasting I popped the clutch and it started up again and drove fine for a lil while and it happens again .... so it stalls and so on... till I got home and parked it... I changed the oil and filter looked in manual put the the right amount of oil, tried starting it and it sounds like it wants to fire up, but just wont....
So i parked it over winter in a shed... Drained all the gas out because it was sitting there for so long... Just curious what would happen if it was ran with 2 much oil for awhile???
Now that theres some nice days I have been messing with it... took the K&N filter out and tapped like ALOT of dirt/sand..... I mean the pile was pretty huge, and I kno that cant be good... I dont wanna start it up untill I get a better Idea of whats up.
p s ... im glad i found this website its got alot of good comments/questions that will help me :naughty:
  • captb
Posted April 17, 2005 - 10:06 PM
I can only say what I would do clean everything, adjust the valves, clean out the carb, check the fuel screen in the tank (petcock screen) check the sparkplug, make sure the oil filter is installed correctly, you should have a service manual, good luck!
  • bikerider420
Posted April 18, 2005 - 08:15 AM
Thx sir....I took the carb off and it seems like it got some buildup in it.... I swiped my finger inside and some dirt came off on my finger....
also, what happens if u run the bike with too much oil, like what kind of probs could happen? :naughty:
  • Hot  60 replies
What was your path to Beta? by officialhopsof
Dirt Bike   Make / Model Specific   Beta
  • Hot  79 replies
  • 7 replies
  • 17 replies
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  141 replies
