chain wear on sub-frame
5 replies to this topic
  • timcook
Posted April 15, 2005 - 09:54 PM
Anyone ever noticed if their chain has contacted the inner portion of the aluminum sub-frame above the chain? :naughty: :naughty:
  • clark4131
Posted April 15, 2005 - 10:01 PM
Yep. It's something of a design flaw. All the WR's have it. There isn't a whole lot you can do other than rig some sort of protection like an extra piece of aluminum, inner tube or similar fix...SC
  • RB2
Posted April 16, 2005 - 07:27 AM
Yeah. I got it too. Only 10 hours on the bike. Like Steve says not much you can do. If any has any ideas or pictures of fixes it would help a lot of us out
  • 99wr400
Posted April 16, 2005 - 11:04 AM
weld a piece of 1/8 inch aluminum to the inner side of the subframe that gets rubbed by the chain, make the aluminum piece as long as the part of the sub-frame that can be touched by the chain.
  • mmi100sguy
Posted April 16, 2005 - 04:08 PM
is anyone using the tm designworks chain slider to fix this problem? i know i've seen the post about putting foam & silicon but i just figured this would look if not work better
  • INJURY_69
Posted April 16, 2005 - 05:16 PM
I use that TM chain slider...seems to fix the problem so far. It is a thick heavy duty unit that doesn't move or use any of the factory bolts/nut-washer-thingy. :naughty:
