coolent out the weep hole in bottom of motor
3 replies to this topic
  • LBMrider27
Posted April 15, 2005 - 10:34 AM
Any body had coolent come out the weep hole under the water pump on their 450. im geussin my water pump shaft or the seals r bad. any one got any ideas?? :naughty:
  • Frostbite
Posted April 15, 2005 - 11:42 AM
It's very common. The seal and or the shaft is probably bad. I've replaced mine 2ce in 5 years.
  • Matt96xr6
Posted April 15, 2005 - 05:10 PM
2 in 5 years? Be sure you replace the bearing also there. That is most likely the cause of 2 seal failures.
Also swap to the dexcool antifreeze. It contains NO silicates like the green stuff. The silicates leave deposits that can eat at the seals.
  • Frostbite
Posted April 16, 2005 - 05:24 PM
I replaced the bearing once. :naughty:
How cold can Dexcool get? I ride cold and have tried a lot of coolants. Polaris -52 premix is the only one that doesn't turn to toothpaste overnight so that's what I run.
  • 10 replies
  • Hot  47 replies
  • Hot  36 replies
