Gray wire...quick question
13 replies to this topic
  • WaGuy78
Posted April 14, 2005 - 07:52 PM
I know this is probably a dumb question, but did you guys pull the wire on the front of the connector (handlebars) or on the back (gas tank). Does it matter at all?
I am planning on pulling it vs cutting it...
  • DCaddy
Posted April 14, 2005 - 09:18 PM
Try this link for all the info you need to disconect the grey wire. You"ll also want to seal the "now empty" hole in the plastic connector with a small dab of RTV silicone to keep it water tight.
http://www.thumperfa...m/gray_wire.htm
  • JeffWR
Posted April 15, 2005 - 02:55 AM
I unplugged the one toward the back by the gas tank. It also points down (the back of the connector) to help keep water out. I don't think it matters which side of connector you disconnect the gray wire.
  • freestyle250
Posted April 16, 2005 - 08:25 AM
i have heard you have to remove the gas tank to do this. Is that true?
  • RB2
Posted April 16, 2005 - 09:49 AM
I just did the gray wire on my 05 wr and i did remove the tank :naughty:
  • new04450
Posted April 16, 2005 - 04:40 PM
I just did mine also- Off comes the tank- It was a quick job, and more than worth it
  • goldy33
Posted April 16, 2005 - 06:25 PM
Just Picked Up An 03 Wr450 With 400 Miles On It, Put Gyt Insert In, Took Throttle Lock Out Replaced With Yz One-bike Rips Pretty Good Now-does The Grey Wire Make That Big A Difference-cause I'm Deffinate Ly Willing To Try-anybody?
  • WaGuy78
Posted April 16, 2005 - 08:45 PM
I just did my gray wire yesterday and took my bike out today... All I can say is :naughty::naughty::D
  • goldy33
Posted April 17, 2005 - 12:43 AM
well if that is the case i will do mine this morning and let you all know the results,but it sure sounds like every body but me already knows-thanks:applause:
  • goldy33
Posted April 21, 2005 - 03:32 AM
yup:cheers:ya'll were right, it rips:banana:any other tips:smirk:
  • waterdog3
Posted April 21, 2005 - 06:31 AM
Buy The James Dean Jetting Kit Off This Site. It's The Only Way To Go. And Install A Lower # Leak Jet, To Take The Initial Bog Out Of The Throttle Responce..#40
  • jayled
Posted April 21, 2005 - 06:53 AM
I tried my 05 wr 450 with and without the grey wire. I have the JD kit, quickshot, air box insert removed, modified throttle stop and the samll plug in the exhaust removed.
My first impression is when the grey wire is cut the power comes on hard right off the bottom. With the wire in place the power seemed more under control off the bottom then opened up in the mid. I only rode in my acre lot. I'll get more feedback this weekend.
Does anyone else feel this way about the wire?
Note: I didn't drill out the air box or completely remove the exhaust insert and drill out the internal baffle because of noise. The number one reason people hate us is NOISE.
Ask yourself how many squids you see with the loud pipes thinking they are fast.
Sad thing is when you ask them why they think they need the loud pipe they tell you off.
  • wrooster
Posted April 22, 2005 - 01:01 PM
My first impression is when the grey wire is cut the power comes on hard right off the bottom. With the wire in place the power seemed more under control off the bottom then opened up in the mid. [...] Does anyone else feel this way about the wire?
refer to
http://www.thumperfa.../gray_wire2.htm
jim aka the wrooster
'01 wr250f
  • jayled
Posted April 24, 2005 - 04:15 AM
been there done that...
It makes a weak attempt to answer my question then he says "or not" .
MMMM k.
I'll reread it.
Bottom line is I will add a switch to see what it does at race speed.
Thanks,
J
