Torque specs needed for rotors/sprocket
4 replies to this topic
  • honkylips
Posted April 13, 2005 - 12:00 PM
Can anybody give me the torque specs for front and rear rotors, plus the rear wheel sprocket? Thanks. Oh, and would this be a lock-tite application?
  • JackAttack
Posted April 13, 2005 - 12:43 PM
It will be hard to get an accurate torq reading with the "blue" loctite you will be using.
Rotor: Just snug them up tight with a 1/4" ratchet.
Sprocket: Will be steel on steel, you can crank them down.
  • Max Power
Posted April 13, 2005 - 01:02 PM
For XR650R.
Front and rear Rotors. 14 ft/lbs with blue locktite.
Rear sprocket. 31ft/lbs. No locktite.
  • honkylips
Posted April 13, 2005 - 03:02 PM
For XR650R.
Thank you.
  • TimBrp
Posted April 14, 2005 - 03:30 AM
Torque the hell out of the rear sprocket. 31ft lbs...sheesh. Try the 31ft. lb's then check it by hand, you'll be amazed at how loose it really is. One thing the manual doesn't take into effect is stretching, warping etc. The contours of the bike do change even after the first ride. However they may be minimal but one thread on a bolt is....minimal too.
