spanner wrench?
15 replies to this topic
  • tnl
Posted April 12, 2005 - 01:37 PM
Is there an alternative to spending $40 at the Yamaha shop for the steering spanner wrench that is called for in the owners manual? I don't care for using a punch to loosen/tightening it. Do spanner wrench's come in different styles and sizes? Or is that wrench specific to the 05 450f?
  • Jackazz
Posted April 12, 2005 - 02:05 PM
I've seen adjustable ones before, but mostly only in old shops & garage sales. You might be able to find some on google or froogle.com
  • sirthumpalot
Posted April 12, 2005 - 02:58 PM
You want this:
http://www.harborfre...temnumber=41243
Works awesome on the steering stem nut, should work on the shock too if you have the shock out of the bike (otherwise no room to fit it), but I've never tried it on the shock personally. The only down side is you cannot connect it to a torque wrench so you've got to guess at the torque.
  • Tubo
Posted April 12, 2005 - 03:01 PM
You won't hurt anything using a hammer and punch. I know it seems a little on the caveman side but most people have been doing it for as long as spanner nuts have been on bikes and it doesn't hurt anything. If you want to be a little more careful you can use a brass punch.
  • NAFLASH
Posted April 12, 2005 - 03:32 PM
ditto, use brass, it wont screw anything up...hopefully :naughty:
  • cowboyona426
Posted April 12, 2005 - 08:34 PM
tnl, the punch method works fine, the spanner nut doesn't get much torque on it at all. After doing my bike last time, I bought the spanner kit sirthump posted and it works great. If not, large vise grips also work.
  • yz426onNOS
Posted April 12, 2005 - 09:12 PM
Punch, if you over do it it will be hard to turn. Then just back her off a bit.
  • sirthumpalot
Posted April 13, 2005 - 02:19 AM
You guys with the punches, if you have ever used the correct wrench and you would never go back to the punch. It's so easy when you have the right tools.
  • OC768
Posted April 14, 2005 - 08:28 PM
Anyone try one of these yet?
http://www.*********...LGshockspnr.jpg
my shop had one for 15$ so I snagged it for doing the shock and works great, haven't tried the head yet though.
  • rmracer27
Posted April 15, 2005 - 03:23 AM
I have used the hammer and punch method also. That nut does not have to be very tight. I think the manual says something like 7ft lbs.
  • skthom2320
Posted April 15, 2005 - 07:21 PM
What's hard about two taps with a hammer and a punch twice a year?
  • sirthumpalot
Posted April 16, 2005 - 04:18 AM
For one the instructions for seating the bearings say that you tighten it up way past what is normal (I don't remember what the actual torque setting is), then back it off then tighten it again. This is much much easier to do with a wrench , no banging things back and forth with a hammer. The tool is under $10, there's no reason not to use it IMHO. :naughty:
  • ncmountainman
Posted April 16, 2005 - 05:45 AM
personally,anything i can do with a hammer that has a 'special tool' is just all the more satisfying :D i've been a mechanic since a child working on my dad's race cars and the hammer is probably the most important tool a man can have. big ones ,small ones,soft ones ,hard ones, my wife enjoys the big hard one the best :naughty: :naughty:
  • tnl
Posted April 16, 2005 - 05:12 PM
Can anyone answer the last 2 sentences in my original thread?
  • Tubo
Posted April 16, 2005 - 05:15 PM
Spanner wrenches come in different styles, sizes and they even make universal spanner wrenches that fit a wide range of spanner nuts. How's that?
  • tnl
Posted April 17, 2005 - 06:19 AM
Bingo! Thanks!!!
  • Hot  28 replies
  • 5 replies
  • Hot  47 replies
