Noob needs advice on 86 XR600
1 reply to this topic
  • scot_douglas
Posted April 12, 2005 - 07:54 AM
Background; just bought my fiance a CRF150 and now I want something to follow her around on.
I just found a 86 XR600 for $300 that has a few problems:
1. Owner thinks the timing chain slipped 180 deg off. Claims it has good compression except it sucks in through the exhaust and blows back through the carbs. He has a friend that is a honda tech that told him to just put a new chain on it and ride it.
2. The front wheel doesn't fit the front fork quite right - his freind ran some part numbers and found the forks are off of a 97 XR400 while the wheel is the stock 600 wheel. Friend suggested using a XR400 hub to make things work out.
So, is it worth the $300 risk? He has all of the parts to complete the bike (except for the 600 forks) - he originaly bought the bike in this contion to build a cheap trail bike - just like me. I'm pretty well versed in chainsaws, er, 2stroke bikes, but I reall yneed some help making my mind up on this.
  • bluestragler
Posted April 12, 2005 - 09:13 AM
Sounds and looks like a worthwhile project to me, but check out the transmission. Check out the timing chain and do the top end while you're in the engine. I'd find a whole front wheel assembly for those XR400 forks. They should work fine for you. You can always find a pair of XR600 forks on Ebay down the road, but try to find '91 or newer, since that would keep you in cartridge forks. If you spend $600-800 getting this bike in shape, you'll have a great bike with a fresh top end for a good price. Good luck.
  • 7 replies
What was your path to Beta? by officialhopsof
Dirt Bike   Make / Model Specific   Beta
  • Hot  79 replies
  • 17 replies
FCR40 Tuning Woes- XR600R by aTuWitty
  • Hot  37 replies
1993 XR600R rebuild by ove
  • Hot  41 replies
