Question about speedometer
9 replies to this topic
  • chawness
Posted April 11, 2005 - 09:58 AM
I have a street legal '92 XR600R, It has a regular round speedometer hooked up to the trip cable. The speedometer is not working. I replaced the cable and it still does not work. I noticed when I spin the front wheel with the cable off the little shaft doesnt turn in the gear box on the front hub. Do you think I need a new gear box or is it possible that whoever installed the front bearings last time didnt do something right?
Thanks
Steve
  • hill5150
Posted April 11, 2005 - 10:06 AM
Lose the cable and get the Trailtech electronic, it works great www.trailtech.com :naughty:
  • chawness
Posted April 12, 2005 - 04:14 AM
That link goes to a trailer manufacturer??? :naughty:
  • hill5150
Posted April 12, 2005 - 05:16 AM
Try trailtech.net.......Or search trailtech computers on yahoo....It's the Panoram model about 75.00 installs in 1 hour.
  • BIG RED
Posted April 13, 2005 - 01:58 PM
Before buying a trail tech speedo try and make your stock speedo work i have a trial tech on two of my bikes and can't stand them!!! there very slow reading and small plus the batterys go dead way to fast
good luck!
  • hill5150
Posted April 13, 2005 - 02:28 PM
Mine works flawlessly... :naughty:
  • jeff leonard
Posted April 13, 2005 - 08:37 PM
Put a trail tech on my BRP for baja and it works great, mileage and speed are extremely accurate.
  • RhedF350
Posted April 13, 2005 - 09:27 PM
It's common on the Honda speedo drives for the two plastic nibs on the gear to wear flat. The corresponding ones on the wheel are metal . The part from the dealer is probably about 15$ now and an easy fix. When you take the drive apart, also clean and regrease the whole assembly. It's about a one hour job total.
  • chawness
Posted April 18, 2005 - 06:48 AM
Thanks. Thats the answer I was looking for!
  • StevePSD
Posted April 18, 2005 - 06:03 PM
I second the TrailTech. The only issue I have is that the speedo display is overly sensitive to changes in speed, the update rate could be reduced or averaged over the last couple of updates.
