tips or tricks to remove throttle stop ?????Help
3 replies to this topic
  • kevin_in_Michigan
Posted November 03, 2000 - 10:21 PM
Tried to remove throttle stop--no luck as of yet--That pin is hard to get a hold of--anyone have a shortcut , I would appreciate it. Thanks--Kevin
  • Guest_Guest_*
Posted November 03, 2000 - 02:06 PM
I cut mine off with a die grinder, with the carb still on the bike.
Hope this helps.
Roy in Michigan.
  • Scott
Posted November 03, 2000 - 02:59 PM
I took the carb completely off the bike and got it off by using needle nose pliers. It was a bitch, but well worth it!
99WR,WR timing,throttle stop removed,Uni filter,E-Series pipe,carbon air box,Pro Tapers,lights removed,YZ tank,13 tooth sprocket
  • Team_Oatmeal_Pie
Posted November 03, 2000 - 09:32 PM
I have a 2000wr and had no problem unscrewing it with carb in place, cut it with dremel tool and put back on with some thread lock. Check the arcives to find out he correct length to cut, depending on the year of your bike.
