Triple Clamp?
9 replies to this topic
  • bigroj
Posted April 07, 2005 - 05:21 PM
I just bought new Pro Taper bars w/ universal mounts and JUST realized they don't fit my 2004 yz450f because the triple clamp isn't compatible. Which triple clamp does everyone recommend?
thanks.
  • 02YZ426
Posted April 07, 2005 - 05:28 PM
I just bought a Vortex triple clamp and I like it alot. I have used the Pro Taper's clamp in the past and it was also really good. My advise, buy whatever is cheapest.
  • cowboyona426
Posted April 07, 2005 - 08:53 PM
bigroj, universal mounts should work with your clamp, you probably just got the ones for rubber mounted clamps. There are tons of places you can get them from around $35 to $60 depending on brand.
  • DPW
Posted April 08, 2005 - 04:38 AM
If you are going to buy a complete triple clamp go with http://brpit.com/ , but like Cowboy said the universal clamps should work.
  • Shuffler
Posted April 08, 2005 - 06:29 AM
will Pro Tapers work with an Applied Racing triple clamp (currently std diameter risers with Renthals) if I get different risers? I'm assuming this is possible... :naughty:
  • cowboyona426
Posted April 08, 2005 - 08:22 PM
Yes, they will.
  • Big Tuna
Posted April 09, 2005 - 08:32 AM
just get the 1 1/8 bar mounts for the applied clamp and your set .
  • mkporn
Posted April 09, 2005 - 09:09 PM
Why don't they work? Are they for the wrong size of forks?
  • Shuffler
Posted April 10, 2005 - 05:53 PM
I bought a used '01 426 with Applied triple clamp & std diameter Renthals. Assuming the day will come when the bars get tweaked, I have some ProTapers that aren't being used, so I'd need to get new oversize risers, or just the adapters that fit the std diameter riser (which raise the bars about 3/4"...not a bad thing since I'm 6'1")
  • cowboyona426
Posted April 11, 2005 - 10:17 AM
Shuffler, you should be able to get all new risers from Applied that have additional rise built in. On my bike with a stock upper triple, I just used the universal adapters, much cheaper than a whole new clamp. Get rid of the Renthals before they bend and get those PT's installed, you won't be sorry!
  • 10 replies
  • Hot  47 replies
  • 5 replies
  • Hot  38 replies
  • On January 15, 2017
