noisey engine
6 replies to this topic
  • greenski
Posted April 06, 2005 - 04:48 PM
my 01 426 engine got real noisey after running some hard laps.I dissasembled the top end and the gear box,the only thing i found was the clutch basket springs which absorb the shock where broken and coming through the basket.so I figured that was the noise and put the machine back together with new basket and piston and rings.Well its still making the same noise. This noise only occurs at idle as I twist the throttle it goes away.
  • sirthumpalot
Posted April 07, 2005 - 02:55 AM
These are noisy engines so by your description it's impossible to tell if your noise is normal. Find another 426 at the track and ask the owner if you can compare his noises to yours.
  • brucer7
Posted April 08, 2005 - 01:48 PM
When I bought my 01 426 I went to go riding with it for the first time I started it up and heard a noise at idle and deceleration. Needless to say I didn't ride it and took it staight to an mechanic. He told me there three nuts behind the clutch side case cover that are known to work loose on these motors. I took it home removed the case cover and low and behold all three nuts were finger tight. one is behind the clutch basket another is on the primary gear and the last one is near the water pump. All have bending lock washers on them. I put it back together and no more noise.. :naughty:) hope that helps!!
  • mkporn
Posted April 09, 2005 - 09:18 PM
Grab your manual, remove the timing chain tensioner and check it out.....It would be one place to look and it is only two bolts..... Mine whent bad and made some terrible noise at idle...
  • MNellis
Posted April 10, 2005 - 04:08 PM
What was bad about your timing chain adjuster?? The only thing in there is a piston and threaded rod along with a spring and a collar. They are all steel pieces. Did something break?
  • biznet1
Posted April 11, 2005 - 03:29 AM
Good call. My primary gear nut was loose. No more noise. :naughty:
  • rws
Posted April 22, 2005 - 03:56 AM
brucer7,
Dude... that is a great piece of advice. I've been chasing the cause of my engine noise for some time... my only problem now is that I'm at work (on a break) and I can't get to my garage to check what you've recommended!
Cough... cough... hmm... perhaps I have to leave due to "illness" :naughty:
P.S. I know they are noisey engines... but it seems that something in mine got "noisier" some time ago.
  • Hot  50 replies
  • 0 replies
  • Hot  38 replies
  • 5 replies
