Front wheel prob?
6 replies to this topic
  • cloute
Posted April 05, 2005 - 07:41 PM
I was reinstalling my front wheel on my yz450f 2004 earlier today. The book says to torque de 22mm nut to 75 ft-lbs. With my torque wrench I put the nut in but never got above 30 ft-lbs and it was still turning!! :D no more threads were coming out. I didn't try to undo it 'cause I was affraid to break it more... :naughty:
So anybody could show a picture or tell me how many threads you guys see out of the nut??
According to my description, do you think the threads are worn out? :D
If yes what's the best thing to do and would it be expansive to replace either the nut or the big bolt?
Can I still ride my bike because there are 4 bolts left to hold the wheel?
Anyway tell me what you think! Tomorrow was suposed to be my first ride of the year!! :naughty:
  • Toobold30
Posted April 05, 2005 - 07:44 PM
First, did you make sure the bolt was all the way through and flush on the right side. Also did you tighten the pinch bolts on top of the axle, if not this will allow the axle to spin inside the hub and forks.
  • Yak
Posted April 05, 2005 - 07:47 PM
Take a look at the other side of the axle while you try and tighten it. I think that the axle is just turning. Tighten the 10mm bolts that clamp the axle on the right (as sitting on the bike) side and try again.
I seriously doubt you could strip those threads with normal hand tools unless you delibrately tried to with a breaker bar, or impact wrench.
  • cloute
Posted April 09, 2005 - 01:48 PM
OH you were right, I'm a shame...
I didn't tight the pinch bolts before DOH!
Now everything is find, thanks everybody for your inputs!
PS: the book says to torque the pinch bolts AFTER the wheel nut...it should say at least to temporarily tight those a little bit before but I should have tought about that ! :naughty:
  • Butta
Posted April 09, 2005 - 06:34 PM
True, but I think the proper way would be to use a large allen wrench to hold the axle while tighening it....but the pinch bolts work, too...
:naughty:
Posted April 09, 2005 - 08:09 PM
The wheel should also be centered after tightenimg the axle. Check the right end of the axle. It should be flush with the side of the axle lug. If not, loosen the pinch bolts on the right side and reposition the fork.
  • ThrakenH04
Posted April 10, 2005 - 08:22 AM
:naughty:
so far, I've never seen an allen wrench bigger then 12mm, and that allen size on the axle looks to be at lease 20mm which in my opinion is HUGE.
