XR650L: Won't start unless it's in neautral - What's up?
4 replies to this topic
  • bluerock5
Posted April 04, 2005 - 10:12 AM
My XR650L Electric start will only work in neautral. It used to start in any gear when I pulled in the clutch. I checked that the 2 wires are still plugged in the the clutch perch. Any suggestions? Thanks
  • ghoti
Posted April 04, 2005 - 12:09 PM
The clutch switch is probably bad. Try disconnecting the wires and jump, (I think it's a normally open switch). If it will start in gear now, either replace the switch, or permanently connect the wires.
  • splat
Posted April 05, 2005 - 11:08 AM
once spliced together they have to be conected to ground to bypass the switch
  • truck6driver
Posted April 05, 2005 - 11:40 AM
Have you checked the kick stand saftey switch?
RH
  • Shakeyhands
Posted April 14, 2005 - 08:49 AM
RH
better yet, disconnect it instead of checking it! :naughty:
