Dropped the 450 in a deep water/mud hole
7 replies to this topic
  • onelugnut
Posted April 03, 2005 - 04:55 PM
I dropped my 05 in a nice deep water/mud hole.It didn't cover the bike but I know I got water/mud in the air box.I wasn't to worried until I started to hear a lot of ticking comming from the motor.I drained the oil, it looked good.
Should I just check the valve clearance and not worry about it?
  • sleeman
Posted April 03, 2005 - 04:58 PM
Your oil had no water in it?
  • Math
Posted April 03, 2005 - 06:05 PM
Don't forget to open the carb ( the screw right under the carb ) there might be some water/mud in there...
  • onelugnut
Posted April 03, 2005 - 06:21 PM
oil looked good ,no water :naughty:
  • onelugnut
Posted April 04, 2005 - 07:02 PM
OK all I pulled the valve cover off and found some what looked like sludge build up.I pulled the vent hose off and it had dirty water in it. :naughty: Tomorrow I am pulling the head off too check the top end.If all looks good is there some way to clean out the bottom end?
  • tagger
Posted April 04, 2005 - 08:44 PM
similar thread going on over in DRZ land...
http://www.thumperta...ad.php?t=240921
  • Canuck
Posted April 05, 2005 - 07:49 AM
my 450 has had a few submarine missions :naughty: .
take the time to go over everything. valves, top end, carb etc.
oil usually is a shade of grey. if not, maybe you let off the throttle before the bike was submerged? check everything anyways for peace of mind
cheers
  • Cedric
Posted April 05, 2005 - 12:05 PM
I did the same thing, silt in my oil, so I tore it down, ended up putting in new rings, valve seals, about 8 bearings - including the mains, a new rod and a few more bits. My bike did not have many hours on it (still on the original front tire). Then when I put it back together, I think I've got a leak on my head gasket and I'm blowing coolant. I'm still dealing with it. This has cost me about $800 (cdn) and that's just for the parts, and I'm still not done.
