Boost XR650L battery
13 replies to this topic
  • Xr650LMartin
Posted March 31, 2005 - 12:47 PM
Hi!! My 650L battery is too low to start the bike after winter storage. Is it better to take it off and charge or can I boost it with my car's battery? Will the alternator be able to charge it full?
thanks, Martin
  • jlpskydive
Posted March 31, 2005 - 03:26 PM
Bump start it and ride it
  • LotsOfBikes
Posted March 31, 2005 - 10:01 PM
I finally replaced the battery in my 1995 XR650L in 2004.. Considering that the bike was built in 1994, the battery was at least 10 years old. I now use the battery as a back-up for one of my camera's.
I'd charge the battery first and see if it holds. The alternator in the 650L is about 190 watts, and should charge the battery quickly. I never had the battery die in my 650L...
  • Shakeyhands
Posted April 14, 2005 - 09:15 AM
thanks, Martin
I've used a 12V charger to start mine, BUT you probably might want to think about replacing it. I wouldn;t use a car battery to do it.
oh... and take your battery off and inside next year! :naughty:
  • Xr650LMartin
Posted April 14, 2005 - 10:43 AM
I finally boosted it with my car, it started right up and the battery now works fine!!
  • Shakeyhands
Posted April 14, 2005 - 11:22 AM
You crazy Quebecois!!! I can't believe you didn't fry the bike! :naughty: :D :naughty:
  • allan68
Posted April 14, 2005 - 03:59 PM
What makes you think you would fry the battery?
Al
  • Eric Henion
Posted April 14, 2005 - 04:17 PM
A Battery from a car has many times the amperage more then a bikes battery therefore bigger means fried bike components. I hope that you were lucky and it did not hurt your bike.
  • Max Power
Posted April 14, 2005 - 04:38 PM
Nice work. Just don't try to start your car with your bike battery. :naughty:
  • Max Power
Posted April 14, 2005 - 04:39 PM
Really?
  • XR650L_Dave
Posted April 14, 2005 - 05:49 PM
There is no problem starting anything with a 12V battery with a car battery. The only problem would be starting something with a battery of more voltage than it should be.
Dave (electrical engineer)
  • Max Power
Posted April 14, 2005 - 06:08 PM
:naughty:
  • Xr650LMartin
Posted April 15, 2005 - 02:22 AM
I'm electrician too! Dave is right! The car battery can deliver more amps but will only deliver what is needed by the starter! amps=volts/resistance! Volts and resistance are the same so amps will be the same!
  • Shakeyhands
Posted April 15, 2005 - 06:52 AM
Well I'm not an Electrician or an Engineer (although I do play one on TV!) but I would have thought that it would fry CDI or sumpin' I don't know nuthin bout no resterance!! :naughty:
