Sputtering in the low to mid rpm range???
1 reply to this topic
  • miah
Posted March 27, 2005 - 01:32 PM
Well I finally got one. I just bought a 03 WR450, I made it street legal to go to and from work when its not the weekend, The problem that I am having is when I am driving in the low to mid rmp range in 1-3 gears My engine sputters. Its fine above that but my pipe is uncorked and gets pretty loud for res. streets. I bought I with all of the free mods done but I do not know how the fuel screw is adjusted or how it is jetted. What will I need to do to fix my problem. I also have some popping when I slow down. Thanks
  • ncmountainman
Posted March 27, 2005 - 03:13 PM
alot of people have that complaint with the JD kit. ask the feller you bought it from. or if you take it apart and the needle is red or blue it's JD's. he's in the jetting forum,and will help you dial it in. :naughty: if its popping on decel turn your a/f screw out a 1/2 turn. turn it all the way in (clockwise) first counting the turns in as your not to exceed 3 turns out. if its that far out already than you need to go up one on the pilot jet.
