Oil change intervule for non racer??
18 replies to this topic
  • 150 Fuelie
Posted March 25, 2005 - 06:01 PM
I see that Yamaha recommends changing the oil every race, but what about for us non racers? Also, what brand and weight do you guys recommend? I'm a big synthetic fan and run amsoil in all my engines. amsoil makes a bike oil in both 10w-40 and 20w-50.
  • FOX426
Posted March 25, 2005 - 06:14 PM
There are hundreds of threads on this. The avg. for non racers or high revers seems to be about 12 to 15 hours.
  • 150 Fuelie
Posted March 25, 2005 - 06:23 PM
Thanks, for me that's about once a year.
  • mayday
every 3 rides and I use bel ray THUMPER earl!!!!! :)
  • rebel1916
Posted March 25, 2005 - 06:56 PM
haha. i have never heard a south dakotan refer to it as earl.
  • 150 Fuelie
Posted March 25, 2005 - 08:17 PM
Why so often, Is the engine that hard on the oil? With the quality of oils these days I don't understand. Today's oils don't break down like just a few years ago. Contamination on the other hand is another story.
  • Wyatt
Posted March 25, 2005 - 08:28 PM
I use Amsoil 10w40 motorcycle specific full synthetic and I change at about 10hrs each time. Sometimes a little less...sometimes more. I have an hour meter on my bike and that adds up to about 3 good trips to the track.
  • 150 Fuelie
Posted March 25, 2005 - 08:39 PM
Filter every time Wyatt?
  • big t
Posted March 25, 2005 - 09:38 PM
I do mine after 3 rides. I use Yamalube 4 and bought a stainless steel filter. I clean the filter every oil change. Paid $40 for the ss filter but the oem filters were $13. The ss filter doesn't take long to pay for itself.
  • 426_Texan
Posted March 25, 2005 - 09:46 PM
It's not a matter of the oil breaking down. It needs to be changed often because of contaminates from the clutches.
  • 150 Fuelie
Posted March 26, 2005 - 05:18 PM
Does the filter media catch the contaminents?
  • Satch0922
Posted March 26, 2005 - 05:30 PM
No. And for the most part all the filter does catch are chunks of metal etc.
I never had an hour meter on my 426 but have one now on my YZ250. Let me tell you...10-15 hours on one oil change on these thumpers is pushing it. REAL ride time for me averages less than and hour and a half each time at the track. I used to changed the oil in my 426 every other ride/race and change the filter every other oil change. So based on my hour meter your talking 3 hours of ride time. Doesn't sound like much but everytime I changed the oil it was nasty and ready to come out.
BTW....my 426 worked flawlessly and never had any cam/valve or tranny problems. I had it for almost 3 years.
  • mayday
Posted March 26, 2005 - 08:57 PM
rebel I grewd up in Alabama and I am sation in SD unfortunately. Because I am freezin my family jewels off! :) No sh8t,my luck the AF sent to Siberia!! :)
  • Wyatt
Posted March 27, 2005 - 08:27 AM
I have the Scott's stainless filter and I clean it with every change.
  • sirthumpalot
Posted March 27, 2005 - 03:50 PM
From the clutch and other areas. But Texan is correct; you change it often because it's contaminated, not because it's broken down. Very important to change frequently.
  • Guest_BrandonV_*
Posted March 28, 2005 - 06:28 AM
I probably average about 3 hrs on an oil change unless I'm out for an entire weekend.
That may seem a bit extreme to some, but the cost of oil is cheap relative to the cost of a major rebuild.
  • Jeremiah
Posted March 28, 2005 - 06:35 AM
Oil changes are important, but make sure you clean your airfilter after each ride!
  • Ga426owner
Posted March 28, 2005 - 06:45 AM
On my 450, I change oil after every race and/or every 3 rides for practice - avg 3-4.5 hrs.
Standard paper filters replace every other ride or complete clean of my SS Scotts filter each oil change.
426 brass filters I would clean and reuse multiple times -
Oil is up to you - I stocked up on Mobile 1 red cap 15 -50..........
  • simimi
Posted March 28, 2005 - 08:38 PM
I had been using a synthetic blend, but switched to the AmsOil 10-40 and noticed a bit smoother clutch feel when it engaged. no slipping. I change it every few rides, when I have time. Maybe 2 rides, maybe 4.
Mike
Motocross
  • Hot  491 replies
  • Hot  36 replies
  • Hot  91 replies
  • Hot  33 replies
