boiling antifreeze
12 replies to this topic
  • JUSTNEIL
Posted March 25, 2005 - 08:49 AM
after about ten minutes of riding i here a hissing noise from my radiator and the plastic tank under the rear fender is boiling. when the bike is cool the radiator and plastic tank appear o.k. . :) any thoughts?
  • simon@vic
Posted March 25, 2005 - 11:44 AM
it happens to me from time to time. but it takes more then 10 min and it only happens on when I'm riding the most insane of single track.
  • WRookie
Posted March 25, 2005 - 04:05 PM
Old coolant?
Radiator fins crushed closed or plugged? Airflow ok?
Is it boiling or is it possible that you have a leaking cylinder and gases are being pushed into the tank?
  • gregwr450f
Posted March 26, 2005 - 12:18 AM
I think it was Frostbite who did some investigation into "heating" of the Wr
450.
Pm him for the details, I think by putting "heat-tape" on the the bottom section of the radiator (not over the finned area) it helped it run 350 degrees cooler.
I hope it wasn't a dream.
  • Tomppa68
Posted March 26, 2005 - 01:44 AM
Take a look at:
http://www.thumperta...ad.php?t=218168
  • JUSTNEIL
Posted March 26, 2005 - 04:57 PM
thanks i got some good info
  • JUSTNEIL
Posted March 26, 2005 - 04:58 PM
thanks for the info
  • PumpkinHumper
Posted March 26, 2005 - 08:00 PM
If its boiling over in 10 minutes there is isues. I wonder if the radiator cap isn't holding pressure.
  • gregwr450f
Posted March 26, 2005 - 08:51 PM
You could be right YZ.
  • TallBoysWRF
Posted March 26, 2005 - 09:20 PM
Is it a 50/50 mix of antifreeze to water? If you have too much water/too little antifreeze, you will have a significantly lower boiling point.
  • Supafreak_711
Posted March 27, 2005 - 05:40 PM
Maybe try some engine ice?
  • gregwr450f
Posted March 27, 2005 - 11:00 PM
Wrong, see the post by "Newblue"
  • JUSTNEIL
Posted March 28, 2005 - 06:13 PM
Thanks Again I'll Keep An Eye On It
