K&N good or bad
5 replies to this topic
  • phixeous
Posted March 24, 2005 - 11:02 PM
is the k&n a good filter for the yzf 450 in the dunes. I see all the race bikes there with them. If I use the outer wear is it good for the dunes, i hear it gives you a little more power then the other filters.
  • rg_series
Posted March 24, 2005 - 11:36 PM
  • big t
Posted March 24, 2005 - 11:48 PM
I would go with the Uni or Twin Air. I have been reading alot of post on TT about the K&N passing some dust. I had one on a four wheeler and it did let some thru and it had the outer wear on it.
  • PK
Posted March 25, 2005 - 08:33 AM
The reason K&N's have a higher flow and may give you a little more power is because they filter less. I don't recall the micron numbers, but I wouldn't put a K&N on anything that sees dirt. There is no way to increase flow without reducing the amount it filters. Twin Air or Uni is a better way to go, especially in the sand...
  • Fastest1
Posted March 25, 2005 - 01:51 PM
Increasing the physical size of the filter would increase flow due to larger surface area.
  • Guest_BrandonV_*
Posted March 25, 2005 - 02:29 PM
I've read many pro and con articles on K&N's, but I can tell you I ran one in my old 250R honda in the dunes for years without a hitch. A fresh K&N wrapped with an outerwear is the hot ticket in the dunes. I still had my airbox which probably helped.........
  • Hot  50 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • 0 replies
