changing oil ?
9 replies to this topic
  • keestan31
Posted March 24, 2005 - 02:02 PM
Well i just bought a 99' yz 400 and before riding it went through all the normal maintnence...when i was changing my oil i took out the bolt on the frame and the oil shot all ove my front tire...i know this is normal but i was just wondering you all take off the front tire when changing the oil or just dont worry about it?
  • MotoGoalie
Posted March 24, 2005 - 02:07 PM
No man, you don't need to pull your front wheel off. :) Just hold a catch basin right in front of the drain until the thing starts tailing off. It's a pain, but XR600 owners have been doing this for years now. :p
That must have made a helluva mess :)
  • XriderR00
Posted March 24, 2005 - 02:45 PM
turn your tire silly
  • keestan31
Posted March 24, 2005 - 03:48 PM
i tried turning the wheel then it gets all over the rim silly
  • keestan31
Posted March 24, 2005 - 03:49 PM
yes it did make a hell of a mess......wasnt ready for it to shoot that far
  • sirthumpalot
Posted March 24, 2005 - 04:13 PM
Put a pan under it, the bigger the better. When you loosen the bolt, DO NOT remove it all the way. I mean unscrew it all the way, but hold it about 1/4" away from the frame. The oil stream will hit the bolt and go strait down into the pan. After about 10 seconds the flow eases up a bit and you can remove your hand and just let it flow. Latex gloves are spectacular for oil changes BTW, the local grocery or drug store probably carries them for < $10 for 100. After a few tries you'll be able to do it without spilling a drop. :)
  • DoctorRzed
Posted March 24, 2005 - 04:34 PM
Or you can just hold up the basin w/one hand on an angle untill the oil lows down???duh
  • Goosedog
Posted March 24, 2005 - 04:51 PM
Since my first oil change, and after I cleaned off the front tire, I started to pull the case plug first and then the frame plug after the pressure was down a bit. I don't know why that should be a problem even though it's against manuel procedure. :)
Posted March 24, 2005 - 05:46 PM
Too complicated.
  • WheelsUp
Posted March 24, 2005 - 05:55 PM
The Billy Who Manfunnel works just fine.
Next week, we'll see if it still works with a Utah skidplate installed :)
  • Hot  33 replies
  • 5 replies
  • Hot  36 replies
Motocross
  • Hot  491 replies
