Kickstarter slop
4 replies to this topic
  • R_Little
Posted March 21, 2005 - 08:40 AM
My '00 has developed quite a bit of slop in the kickstart "knuckle" joint.
I this an issue or can I leave it like that. If I leave it, will it break and strand me.
How best to fix it or must I replace it.
Thanks
  • tgodwin
Posted March 21, 2005 - 09:09 AM
Mine did the same. I pulled it apart and streched the spring behind the ball bearing. This helped a little, but I still ended up replacing it.
It is a bad thing to have the kick arm come swinging out while you are carving through the trees or taking a little air. It bit me on several occasions and I think falling pn it with your leg in the way may do some real damage. Bottom line replace it. I tried to get the BBR billet model from Thumper talk, but they no longer make it, had to get a stock arm. Works great, no worries.
Cheers,
Tim
  • R_Little
Posted March 21, 2005 - 10:39 AM
Good points!!!
I'll replace. What did it cost you?
Thanks
  • tgodwin
Posted March 21, 2005 - 11:42 AM
Not cheap, like $75.
  • Bamster
Posted March 21, 2005 - 03:12 PM
Mines a little slopy but it stays in.
Your making me worried.
