YZ425F Does not start in Cold/Cool Weather
6 replies to this topic
  • wkimmell
Posted March 20, 2005 - 03:41 PM
My 2000 YZ426F does not start when it is cool outside. That is, when the temperature is lower than 60 degrees. I live in Missouri and I am not able to ride in the winter. Any recommendations would be appreciated.
  • 642MX
Posted March 20, 2005 - 03:44 PM
Have you checked the valves or replaced the spark plug lately?
  • MXof21
Posted March 20, 2005 - 04:22 PM
My 2003 YZ450F needs a couple of twists of the throttle when it's cold, I also turn the idle up one full turn.
  • 02YZ426
Posted March 20, 2005 - 05:28 PM
Ya.. that usually works for me too. Just dont twist the throttle while kicken it over. Dont do it more that 2 or 3 times either, or you will flood the engine out.
  • ChasYZF
Posted March 23, 2005 - 07:58 AM
If it's not spark plug or valves then be sure and check your ignition stator!!! I intallled an ICAT Igniton module, and that seemed to help cold starts alot.
  • SureBlue
Posted March 23, 2005 - 12:30 PM
[quote name='wkimmell']My 2000 YZ426F does not start when it is cool outside. QUOTE]
Cool air contains more oxygen than warm, so your bike gets too lean mixture. You need to open up the fuel screw half a turn (counter clockwise). This should help. You perhaps also need to go for one larger main and pilot.
Turning the idle up (clockwise) one full turn is a good idea too.
  • Fastest1
Posted March 24, 2005 - 04:29 PM
Actually the main wouldnt change starting at all, but if it needs a larger pilot because of the cooler air, a larger main is probably wise for the most top end. But as mentioned start with the fuel screw.
  • Hot  36 replies
  • Hot  28 replies
  • On January 15, 2017
Motocross
  • Hot  491 replies
