YZ426F Does not like to start in Cold/Cool Weather
4 replies to this topic
  • wkimmell
Posted March 20, 2005 - 01:51 PM
My 2000 YZ426F does not like to start when it is cold/cool outside. Basically, it will not start when the outside temperature is below 60 degrees. Other than that the bike runs like a champ!
I live in Missouri and I am unable to ride during the winter. Any recommendations would be appreciated.
  • PumpkinHumper
Posted March 20, 2005 - 04:07 PM
You need a biger starter jet. NOT the pilot jet...The Starter jet. The starter jet only works when the choke is on. A larger starter jet makes for a richer choke circuit.
Although if it is cold enough out you may need to go richer with the pilot, main, and needle. but if you are only aroun say 40-50 deg try one size bigger on the starter. Any colder and I would try playing with the jetting.
  • SWD6
Posted March 20, 2005 - 04:37 PM
Turn the throttle a couple of times before kicking :)
  • Roosted
Posted March 20, 2005 - 06:48 PM
http://www.thumperta...ght=Starter Jet
I put a bigger starter jet in my 03 WR450 and it starts much better now. They do like fuel on start up. I usually have to give mine 4 or 5 turns of the throttle.
  • WRookie
Posted March 20, 2005 - 07:11 PM
I ride year round with the stock starter jet. When it's colder I twist the throttle a few times. We have had a pretty mild winter so I guess if I had trouble keeping the bike running with the choke on I would try a bigger jet. I just have not had to.
