James now infos?
3 replies to this topic
  • Sylvain
Posted March 20, 2005 - 12:11 PM
Hi guys
I'm cleaning the carb and would like to do the James now mod. I did search TT about it but all the links I found don't work anymore. I'm trying to find the plans on how to make the mod. I remembered there was a file on that but I can't get it. :)
I should of made a print when it was there :)
Thanks
  • Brettv
Posted March 20, 2005 - 08:26 PM
i had the file, but found that its best if you measure your own up and make sure, if you have a pair of venier calipers they work great, get some 1mm thick steel and have a play, cut two tabs for the back so it looks like a T so it wont get sucked in, the air boot will also help to hold it in, i made one for my wrf400 99, works great, i did put some liquid metal in as well, to stop it flapping a bit, seems to have held up well
  • mjslim
Posted March 20, 2005 - 09:03 PM
Here you go, no charge :)
http://www.thumperfa...s/JamesNOW!.pdf
  • Sylvain
Posted March 21, 2005 - 08:00 AM
