rear wheel bearing...xr650-r
1 reply to this topic
  • djinnzfree
Posted March 20, 2005 - 07:56 AM
is it easy to perform a change?
need special tools?
is there c-clip for retaining bearing?
did anyone got the numbers who's write on the side of the bearing... just to check if i can find something as jobber one...
thanks...
  • TimBrp
Posted March 21, 2005 - 04:12 AM
I used a bearing punch for mine. If you look down your axle shaft there is minimal rooms to work around the collar and actually tap at the bearing. You'll need, I believe, a 20mm punch and they'll come right out. Make sure you pack the new ones with grease.
