2003 WR450 Valve Inspection 3,000 Miles
9 replies to this topic
  • DRZBigB
Posted March 19, 2005 - 02:55 PM
I just helped my Brother check the valves on his 2003 WR450F...
I got these specs from a post on here - Are they correct?
Intake: .004" - .006"
Exhaust: .008" - .010"
HERE ARE THE ACTUAL CLEARANCES ON THE BIKE:
Intake 1: .004 Exactly
Intake 2: .0035 (In Between .003 & .004)
Intake 3: .0035 (In Between .003 & .004)
Exhaust 1: .008 Exactly
Exhaust 2: .008 Exactly
SO - Do I need to reshim Intake 2 & Intake 3???
Is is CRUCIAL or is it OKAY?
Thanks!
  • RNS
Posted March 19, 2005 - 07:00 PM
Its Crucial to keep the valves in spec.
RNS
  • vmxr
Posted March 19, 2005 - 09:31 PM
I would reshim if it were mine.
  • Indy_WR450
Posted March 19, 2005 - 11:08 PM
Yes do them all to the high side or even .001" over the max clearance. :)
  • DRZBigB
Posted March 20, 2005 - 12:22 PM
Thanks - I'll tell my brother we need to reshim - are you SURE .001" OVER the specs, or just .006 and .010
  • Indy_WR450
Posted March 21, 2005 - 05:35 AM
Dont go over unless you cant shim it close to the upper tolerance. :)
  • DRZBigB
Posted March 21, 2005 - 01:19 PM
We discussed it, and we are going to shim ALL the valves to the MIDDLE of the specs..
Intake: .005
Exhaust .009
I don't forsee them tightening up any more, and if they do, I'll just reshim it to the middle again in a year or so...
Sound Right?
  • Oasis_Flame
Posted March 21, 2005 - 01:24 PM
I went to the high side when I first did my valves and noticed lifter tap when the motor was up to temp. I now have them at .006 on intake and .008 on exhaust with no noise. :)
  • DRZBigB
Posted March 22, 2005 - 08:19 AM
Why would you put the intake at MAX spec, and Exhaust at MIN - is there ANY advantage, or just the "Tap,Tap,Tap"
  • vmxr
Posted March 22, 2005 - 11:59 AM
In the Jan 05 issue of Dirt Bike Magazine pg. 51, there is a description of the set-up on the Glenn Helen 24-hour winning YZ450 of Ty Davis. It mentions that the valve clearances are "set a thousandth looser than normal". I assume this is done for reliability. I have no idea what "normal" means in this context. But FWIW, I always set mine to max specified clearance and have had good results over more than 5000 miles on my 03 Wr450.
That said, I think if you check your valves regularly, and run the clearances in the middle of the spec there should be no problems.
