Hydraulic Clutch YZ426
10 replies to this topic
  • 02YZ426
Posted March 17, 2005 - 06:22 PM
I want to convert my standard cable clutch to a hydraulic clutch. What do you guys think of the Magura clutch conversion? Anyone tried one of these? If any of you guys have a used one to sell, or know where to get them for a decent price please fill me in. Thanks
  • adrian
Posted March 17, 2005 - 07:14 PM
ebay 210.00 us for a magura
  • Dano426
Posted March 18, 2005 - 11:56 AM
I just posted one on ebay Item number: 4536821961
http://cgi.ebay.com/...me=STRK:MESE:IT
I took it off my 01 YZ426 after installing a z-start. The clutch pull was bettter than stock, but the best part was it never needed adjusting :)
Good luck in your search
  • fastenuf4u
Posted March 18, 2005 - 12:24 PM
02YZ426,
I put a Magura Hydraulic Clutch on my 03 and I will never ride another bike without a juice clutch again!! The clutch pull is 2 finger easy, heck the first time after I was riding with it I got freaked out thinking it had lost pressure because it was so easy. The other cool thing is the fade resistance of them, you can abuse your clutch more and not have to adjust the cable manually. You should see people's faces when they walk up and pull the clutch in not knowing it's a Hydro, their jaws drop! :) Good luck!
  • islandboy
Posted March 18, 2005 - 06:02 PM
How does the Moose EZ Pull compare to the Magura system?
  • Fastest1
Posted March 18, 2005 - 07:42 PM
Though I have never tried the Moose system, I do understand how it works. It will reduce effort however it will take more travel to do so. Trade offs suck.
  • JohnB
Posted March 18, 2005 - 07:48 PM
I might get bashed here.... Not to change the subject....
Put your money towards a Rekluse clutch. You'll never need to use the clutch again.
  • cabage
Posted March 18, 2005 - 11:29 PM
Hello mate, I too have the Magura on a Yz526 02, but to be honest don't notice hardly any difference, have I installed it correctly :)
  • fastenuf4u
Posted March 19, 2005 - 05:54 PM
cabage,
Are you saying you can't tell the difference in the clutch pull after installing your Magura? I am not sure what a stock 426's clutch pull is but I know mine is seriously reduced. Did you have an aftermarket lever on before installing the Magura unit? This may have lightened up the pull enough to make it hard to notice the, if any, reduction in pull. I had a friend with a stock 03 450F sitting right next to mine so I could compare, and the difference was pretty amazing.
  • 02YZ426
Posted March 19, 2005 - 08:43 PM
I am definatly going to buy the Magura clutch.....Ive just got to see the differance myself. Im hoping its going to make a big differance. Is there any real differance between the Magura Jack and the previous model? Just curious because I can get one of the earlier modles alot cheaper.
  • sanpedro426
Posted March 19, 2005 - 10:13 PM
A friend of mine has the magura juice clutch , and IMO i cannot tell the difference between his and my stocker. I keep all my cables lubed with a cable lube. I swear by the little cable luber you clamp on the end and squirt lube into it. Dont see the need to spend the coin on that magura system. Just my oppinion. :)
  • 0 replies
  • Hot  36 replies
  • Hot  38 replies
